2nd2a_corrado
Gerbil noises from vr6
tried 3 garages and no-one knows, so...
persistant high pitched squeaking gerbil noises from a vr6 rado engine, doesn't seem to be related to engine temperature, worse in the damp and squeals higher with revs, not speed. any ideas?!
thank you!
This could be the bearing in the alternator belt tensioner. Does it sound like a chirping grating noise?
This tensioner is around £100 from VW but you can actually buy it from Ford for around £75. Ford can supply this because the VR6 engine was used in the Galaxy/Sharan which was a joint venture of Ford and VW. As far as I'm aware it makes no difference that it's the 2.8 litre version.
Also, you can actually buy the bearing yourself from a bearing supplier like BSL. It's a 6203LH, but they didn't know what the LH meant so they gave me a different version of the 6203. It cost me £12. I have yet to fit it so I don't know the success of it. I believe it requires some cutting of the original roller in order to get the old bearing out and then a glue job to keep the new new bearing in.
Alan
