cheesy 0 Posted February 15, 2011 (edited) hello all The 4th Installment I'm back in corrado ownership with a 2.0L 16v this time Moonlight Blue Pearl Lots of History & money spent Stainless cat back exhaust fitted Came with an Alpine cd player Needs some tweaking on the cold start/idleing Windscreen needs replacing, gonna have a tiny bit of rust treated on top of a pillar when the damaged one comes out Been 5 years since i last owned a G60, looking forward to having some fun in this one anyhow here we are Edited October 25, 2011 by cheesy Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted February 15, 2011 Welcome back---Good looking Car bud Quote Share this post Link to post Share on other sites
Abdul 0 Posted February 15, 2011 Very nice mate, I do like the standard cars alot I must say! Quote Share this post Link to post Share on other sites
cheesy 0 Posted February 16, 2011 thanks for the comments hopefully gonna look into the cold start running later today Quote Share this post Link to post Share on other sites
Wompa 0 Posted February 16, 2011 Love the color mate! Quote Share this post Link to post Share on other sites
cheesy 0 Posted February 22, 2011 Cheers wompa Looked at the cold start issue & looks like its the isv after a quick clean gonna have another go at cleaning it or replace it Had a nosey at the sunroof as was told it was faulty, That looks like the typical fault so needs a repair kit Heater panel lights weren't working, wiring wasnt plugged in so easy fix Cars been sat for couple of weeks doing nothing, passenger carpet is wet so gonna look into that, Having a 9A engine delivered today that i'm gonna give a refresh to, and do a few bits & bobs then get it fitted Quote Share this post Link to post Share on other sites
Diesel Junior 0 Posted February 26, 2011 Welcome back cheesy, thats a really nice straight original Corrado you have there. What sort of economy do you get according to the MFA, will be in UK this summer with a 16v on the shopping list and would be interested to know! Just done 1000km to Madrid and back and got 33 mpg with the cruise control set at 130kmh.....good luck with the car! Quote Share this post Link to post Share on other sites
cheesy 0 Posted February 28, 2011 Diesel Junior I havent got it on the road at the minute as theres a few bits & pieces i want to sort out first Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 9, 2011 havent had much time recently to get anything done but picked up a complete b4 moonroof assembly today so thats the job for tomorrow Had an uprated headlight loom delivered Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 10, 2011 today was just to spend a few hours doing a few bits and pieces So Old sunroof cassette out & the B4 Passat moonroof in Really easy job to do, airlined out the drain holes My o.e motor is dead so bolted the passat one up for the time being till a replacement is bought I've been trying to get the tumblers to retumbler a couple of locks but vw wanted £50 Stripped down the glove box and went old skoll on the barrel. smoothed down worked at treat Boot lock, well stripped it down gave it all a damm good clean and was fine just got that much crud in it, it wasn;t operating off the key does now so good couple cheap fixes Replaced the seal round the heater ventilation in scuttle bay, old one had seen its day Tracked down the ABS to a blown bulb, put my test light onto it and stays on all time so need to get the abs ecu read & new bulb unit thats about all for today, few more bits to look at next week on me days off Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 16, 2011 Nearly got the colst start idleing sorted, which is down to the isv Also fitted some all red rears Quote Share this post Link to post Share on other sites
cheesy 0 Posted April 26, 2011 Not updated this for a little while Not been to well for a few weeks myself then my grandad passed away, So, Purchased some spax adjustables with 40 or 60mm drop Front strutbrace Been purchasing lots of bits & pieces for my spare engine Painted my spare engine black, rocker cover red & inlet manifold satin black Fitted new flanges, cambelt tension etc, water pump, fitted kr cam, new timing chain spent the weekend swapping over the engines got some bits and pieces still to connect bolt up first off need to sort out a manifold as my o.e was has a crack in it Quote Share this post Link to post Share on other sites
cheesy 0 Posted May 4, 2011 Not done alot else due to time really But refitted airbox Installed new donut seals onto injectors that have been all cleaned out ht leads fitted rad refitted & assiociated pipes & wiring MK4 header bottle & wiring done Still got thermostat & lower hose to fit Exhaust manifold when it arrives fill with fluids then should be good to prime everything up then fire into life Quote Share this post Link to post Share on other sites
cheesy 0 Posted May 11, 2011 Well after another few hours working on the car got the manifold fitted & dowpipe refitted the inlet manifold & TB & hose to air box Fitted alt belt & alternator PS Belt & tensioner set up Thermostat & housing Lower hose for rad Lower hose for water pump to water hard pipe Filled with fluids, everything primed And after a little while sparked into life no apparant leaks so spot on Also changed the abs light for a new one and works a treat, comes on and off as it should Quote Share this post Link to post Share on other sites
cheesy 0 Posted June 27, 2011 Picked the car up from having it lowered Sits well & ride is alot better than i thought it would be Spax shocks & 60mm springs, Damping adjustable Quote Share this post Link to post Share on other sites
cheesy 0 Posted October 25, 2011 Not done anything with this for a while, work & health getting the way But have fitted g60 brakes, mk4 rear calipers new solid brake pipe from abs Had the broken windscreen removed to see the extent of rust damage underneath that needed attention Then had the bodyshop work there magic ready for the new windscreen going in Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted October 26, 2011 looks like you got that rust in time, mine needed welding! and extended further up towards the trim, how much did it cost you to have the screen removed if you dont mind me asking? it took me an a m8 3 hours to cut mine out, was roight a pita , mainly because trim peices were glued in by a screen fitter and my wire kept on getting snagged on em :( Quote Share this post Link to post Share on other sites
cheesy 0 Posted October 26, 2011 looks like you got that rust in time, mine needed welding! and extended further up towards the trim, how much did it cost you to have the screen removed if you dont mind me asking? it took me an a m8 3 hours to cut mine out, was roight a pita , mainly because trim peices were glued in by a screen fitter and my wire kept on getting snagged on em :( The metal was still solid, bodyshop said there were 2 very small holes appearing at bottom of pass a pillar which they have sorted windscreen was removed by auto windscreens on insurance, they were happy to come out, take the cracked one out then come back few days later after the work had been done just for the cost of the glass cover on my policy the screen that was in had been overly added with sealant & may the fitter swear a couple of times on removal, took him about an hour to remove Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted October 27, 2011 ah right ok, so your screen needed replaceing anyway? so at the same time you got the rust sorted! 2 birds 1 stone ;) take a look at my thread,http://the-corrado.net/showthread.php?56705-my-vr6-Shed-on-Wheels-../page4 on page three you can see the bubbles which were prety nasty!! and holes where you described aswell! think because its on a curve and the metals thinner maybe? Quote Share this post Link to post Share on other sites
Danno 10 Posted October 30, 2011 Colour looks awesome! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 30, 2011 Great pics Cheesy! Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 30, 2011 Nice work done there . Had my pillars replaced when she had a full respray as they were rotten as a pear . Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted October 30, 2011 Good work! Always a worry on older cars- you never know what you're gonna find under there. Quote Share this post Link to post Share on other sites
cheesy 0 Posted November 1, 2011 picked the car up today and paint work & new windscreen fitment looks spot on Cars now gone for ignition timing setup, mot, full pressure brake bleed & new battery Had a quick play on vag.com Erased a couple of fault codes on the abs & found the tb postion sensor as a fault ran out of time looking into other things but a great program, first time i ever used it Quote Share this post Link to post Share on other sites
