daveme
Wanted - Drivers Side Exterior Door Handle
I have a 1993 VR6 Corrado and need a driver's side exterior door handle. The old one was drilled off and hence I need more than just the fix supplied by daves16v.
I have a handle taken off my 1994 vr6 corrado. it's in perfect working order but the best of it is that the alloy striking arm has been professionally replaced with a steel part that does exactly the same job but will never snap as with the original alloy handle interior. I have had numerous handles break on me in the past so i decided to finally put paid to this common fault & it led me to coming up with a permanant solution. I also have the passenger side handle on which the alloy striking arm has been replaced. Let me know if you're interested :)
