ray_vr6
Clifford and upgraded headlight loom
Hi
Just wonderering if anyone can tell me if I have "upset" my clifford concept 50 alarm by fitting an upgraded headlight loom.
Since I fitted the loom (big difference) I am getting warning messages when I first start the car "attention sensor 1 was active" and "boot trigger was active"
I am guessing it may be something with voltage but hoped someone might be able to confirm or point me in another direction.
Thanks in advance
Where is your alarm's bonnet switch located? Any chance you could have pulled the spade connector off by accident when fitting your loom?
Hi kev
That was my first thought as the bonnet switch is right by the battery/loom set up but all looks ok when I checked it. Maybe I should check again.
Thanks
I would cut the spade off and put a new one on if it looks all crusty anyway. Maybe fiddling around in that area has highlighted a weakness?
