J Collins
Noisy Dash
firstly, check all the screws are tight.... This is the kind of area that alarm fitters dismantle to fit alarms and imobilisers and some of 'em are sods for not putting all the screws back in tightly... :roll:
If that's not it, go out and buy yourself some sticky backed black felt, try and work out which bits are rubbing together to make the rattle, and coat one of 'em with the felt. Tada! - Rattle cured. ;) 8)
I had a similar problem with my Corrado and it turned out to be the indicator stalk rattling.
It was the end piece of plastic on it and it just needed glued.
