corrado_sunderland
please help electrical issues with dash gauges- 1.8t rado
This is about the most annoying thing thats ever happend on the car yet.
A lad has flown all the way from italy to view the jet today and he had a half hour drive was happy then all of a sudden on the way back get round the corner from my house and the digital display on the dash goes blank, rev gauge goes off and speedo too :(
Took the car out tonite to drop a friend off and the spoiler isnt auto coming up as it musnt have a feed from the speedo also. The car before you start it now has no coolant or oil red light but handbrake and battery lights come on.
The car has no speedo still, no rev gauge but temps, green backlight and fuel work fine :S,
Ive checked all the fuses and none are blown so im stumped and ive got no idea why its just randomly happend
Any ideas?
theres a box of tricks behind the dash just below the headlight switch have a play with the connections on that or replace it with a known good one, other than that im afraid all the wires go back to the fuse board you might have a didgey loose connection in there....just make sure all the connectors are pushed home properly
it could be your clocks have gone belly up. the loom from the clocks has 2 blue plugs in the fuseboard. make sure they are in properly.
