hi, i have a squeel on startup only for a few seconds then this goes, is this the fan belt? if not what is it, how do you fix it and how much usually....
Thanks. :bonk:
I would say so, either that or the alternator belt. The alternator belt can be adjusted, not sure about the fan belt. Though they will start to squeel again as the noise is due to wear. Prob best to replace.
slipping belt, check the tension of them, how far can you deflect the belt with firm thumb pressure halfway between the pulleys? should only be about 5-10mm
Yep new belt is cheap as chips so best of replacing. mine was doing this when it was cold !! You should not be able to turn the belt round on its self any more yhan half way
