Haribo
Late spec rear demister switch and light switch
the activated ring light has stopped working on the demister switch so I cant tell if its on or not and the middle light doesnt work on my light switch, cant find the bloody thing when its dark :p
anyone?
Harry
Both of those should be easily fixable if you have a soldering iron. Get a couple of small 12v bulbs from Maplin, or more preferably for the icon in the lights switch a 12v led rather than a bulb as it generates less heat.
When you open up the delimster switch be very careful - there are 2 spring loaded 'posts' which have a tendancy to ping out. The best way I've found to keep everything in place is to open it upside down and slowly. The light switch is easier to get into. You'll need something like a set of thin watchmakers screwdrivers to get into them.
