Bournemouth James
how to remove a door
No, just two bolts on the hinges,open the door up and have a look at the hinges you'll see them ,obviously remove wiring and door check strap as well. :mrgreen:
Its seems a bit to much for a lock problem to remove the hole door :?
having a real bad problem with it, after adjusting it and not testing it before i shut the door, i now cant get the door open atall, ive tried everything
I dont think im guuna b able to remove the door with the door shut, ill have to try some other way to get it open
ther's probably a couple of screws holding the panel in place, which are now nicely hidden by the door shut.... get the Angle Grinder out :shock: :shock:
