Sypher50 0 Posted February 26, 2004 Hi, when i start up my C in the morning whens its cold it sputters extremely when i accelerate...when its idling its perfectly fine and doesnt sound like anything is wrong...only when i step on the gas....then after warms up it only hesitates once in a while with a load. If you could help me. Thanks Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted February 27, 2004 could be the MAF, coil pack or the blue temperature sender. hard to tell without seeing the car and getting in on a diagnostics machine/1552/ fault code reader. Quote Share this post Link to post Share on other sites
Henny 0 Posted February 27, 2004 Welcome to the forum... 8) Which engine has your C got in it? Helps with finding problems if we know which it is! ;) *edited due to stupidity... * :oops: Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted February 27, 2004 The subject of the thread might give that away, m8...... ;) Quote Share this post Link to post Share on other sites
Henny 0 Posted February 27, 2004 :oops: OK, I've had a busy morning and a nasty trip to work 'cos of the snow... :roll: Sorry Sypher50, my mistake... 8) Quote Share this post Link to post Share on other sites
gareth naffine 0 Posted February 29, 2004 my vr6 is exactly the same really bad in first mainly and it kangaroos up the road if you find the answer please tell me how to sort it ! Thanks :? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 29, 2004 There's no single answer to these kind of problems. Let's face it, "bad running" is a single symptom that can be caused by pretty much *any* engine fault.. The most common causes of bad running when cold, however, are probably: idle stabilisation valve probs engine temp sensor probs (this would show up on VAG-COM) HT lead problems / coil pack / spark plugs fuel delivery - injectors, fuel pump etc. ..but you could also benefit from a ECU reset, so it re-adapts to your engine's config. First things first, if you don't wanna just replace things, get it on VAG-COM (or equivalent) - any engine fault codes can cause all kinds of inconsistent running. Quote Share this post Link to post Share on other sites
