jakegti
vr6 shopping list
hi, i need to source a few parts, ill get a quote from tps aswell but whilst im online i may aswell have a look around. i need:
vr6 rad
thermostat housing
thermostat (lower opening temp if recommended?)
crack pipe
does anyone have any recommended websites they use for parts like this? i dont want to buy the billet crack pipe btw!
cheers
I deal with the guy all the time. Top notch Ebayer, good parts but not always VW stamped.
bought. only leaves the rad, i heard the gsf ones aren't that good so i will bite the bullet and get one from tps. should i be sitting down when i make the call?
should be under 200 quid
i got a neuspeed stat. the one in that kit will be a backup, but i will do as you say. i dont fancy taking all that apart again with the front end back on
Get yourself a water pump too - may as well do it all in one go. From experience leaks tend to move to the next weakest spot once you have fixed them! Hope your matrix is strong..
Rads are about £250 retail inc VAT from a dealer, so not really *that* bad
thanks mate, ive sent him a message
---------- Post added at 07:43 AM ---------- Previous post was at 07:38 AM ----------
im going to buy a waterpump aswell. may aswell whilst ive got easy access to the front mount
