elnigel 0 Posted May 7, 2011 Hi, Do you have the drivers side lower dash/ under the steering wheel section that covers the fusebox and wiring? If you do is it black? How much would it be posted? Thanks, Nigel Quote Share this post Link to post Share on other sites
stretch. 0 Posted May 7, 2011 Thanks for calling me back so quickly to reassure me tgepphe parts are in the post! Sorry if I seemed a bit abrupt, Ibwas just leaving tontreat the fam to lunch! Thanks again, Quote Share this post Link to post Share on other sites
hunty 10 Posted May 7, 2011 no prob stretch here to help and make buddys ---------- Post added at 10:13 PM ---------- Previous post was at 10:12 PM ---------- yes have in dark grey elnigel said: Hi, Do you have the drivers side lower dash/ under the steering wheel section that covers the fusebox and wiring? If you do is it black? How much would it be posted? Thanks, Nigel Quote Share this post Link to post Share on other sites
elnigel 0 Posted May 8, 2011 How much would you want for it posted? Cheers Nigel Quote Share this post Link to post Share on other sites
rsgntx 0 Posted May 8, 2011 I'm looking for the gear shift surround in grey (not black) needs to be in good condition with no broken clips... if you have one let me know how much please? would be nice to see a pic too... thanks Quote Share this post Link to post Share on other sites
JMC 0 Posted May 8, 2011 Do you still have the drivers door handle please (ideally with a key but not a deal breaker if not) and assuming it has central locking? Quote Share this post Link to post Share on other sites
hunty 10 Posted May 9, 2011 yes have door handle was wanting to keep lock so have full lock set JMC said: Do you still have the drivers door handle please (ideally with a key but not a deal breaker if not) and assuming it has central locking? ---------- Post added at 08:37 AM ---------- Previous post was at 08:36 AM ---------- sold on ebay sorry rsgntx said: I'm looking for the gear shift surround in grey (not black) needs to be in good condition with no broken clips... if you have one let me know how much please? would be nice to see a pic too... thanks ---------- Post added at 08:38 AM ---------- Previous post was at 08:37 AM ---------- yes still it £17 posted elnigel said: How much would you want for it posted? Cheers Nigel Quote Share this post Link to post Share on other sites
james153 0 Posted May 9, 2011 Hi can i have some prices for the following parts Sunroof drain pipe, n/s? exhaust hanger (rear box just by the axel) bracket to hold power steering reservoir Abs Light Plastic runners on the bottom of the drivers seat Thanks james Quote Share this post Link to post Share on other sites
stretch. 0 Posted May 9, 2011 Got the parts today thanks mate :-) Quote Share this post Link to post Share on other sites
JMC 0 Posted May 9, 2011 hunty said: yes have door handle was wanting to keep lock so have full lock set ---------- Post added at 08:37 AM ---------- Previous post was at 08:36 AM ---------- Ah ok, how much do you want for the handle without the lock then? Quote Share this post Link to post Share on other sites
hunty 10 Posted May 9, 2011 £25 jmc said: hunty said: yes have door handle was wanting to keep lock so have full lock set ---------- post added at 08:37 am ---------- previous post was at 08:36 am ---------- ah ok, how much do you want for the handle without the lock then? Quote Share this post Link to post Share on other sites
JMC 0 Posted May 9, 2011 hunty said: £25 jmc said: One final question, can you please check the colour of the wiring to the connector of the central locking. Are the three wires red, brown and black? The reason I ask is that I bought a handle previously but the wires were different to the one that came off my car, and the central locking didn't work, and I'd like to make sure that this is the same as my original one. Thanks. Quote Share this post Link to post Share on other sites
rsgntx 0 Posted May 10, 2011 i'm looking for the black plastic piece inside the petrol flap. this is the part the piece on the flap goes into to allow the flap to lock. there is also a like guard behind the catch that i would like. the part numbers are 535862181A which is the bit i broke then 535862292A for the guard. see pictures below: item 3 and 18A Quote Share this post Link to post Share on other sites
hunty 10 Posted May 11, 2011 have 18a rsgntx said: i'm looking for the black plastic piece inside the petrol flap. this is the part the piece on the flap goes into to allow the flap to lock. there is also a like guard behind the catch that i would like. the part numbers are 535862181A which is the bit i broke then 535862292A for the guard. see pictures below: item 3 and 18A Quote Share this post Link to post Share on other sites
rsgntx 0 Posted May 11, 2011 hunty said: have 18a Well the good news is that i sourced the part that is broken from VW Heritage! :D regarding the guard i cleaned the one i have last night and it turns out not to be in too bad a condition.. I posted on the other breaking threads this morning that i was sorted but missed yours! thanks for looking and so sorry if i put you to any trouble! if you have 17A ollievr6 is looking for one!! All the parts in that group in the diagram are obsolete from VW Quote Share this post Link to post Share on other sites
RobEvans 10 Posted May 11, 2011 I will have your drivers door if it is rust free and still available. Quote Share this post Link to post Share on other sites
hunty 10 Posted May 11, 2011 still have it theres a small bubble patch by bump strip at front of the door RobEvans said: I will have your drivers door if it is rust free and still available. Quote Share this post Link to post Share on other sites
cheddarcheese 0 Posted May 14, 2011 (edited) hey mate revived the part today but why have i only received the flap part of the metering head what about the part that the fuel and injector lines connect to! like you have pictured? for £40 quid i would expect the hole metering unit also http://the-corrado.net/showthread.php?55891-metering-head Edited May 14, 2011 by cheddarcheese Quote Share this post Link to post Share on other sites
Jogort 0 Posted May 14, 2011 Is this a late spec model ? do you still have the heater controls, if so how much delivered. Cheers John Quote Share this post Link to post Share on other sites
hunty 10 Posted May 15, 2011 Sorry early spec jogort said: is this a late spec model ? Do you still have the heater controls, if so how much delivered. Cheers john ---------- Post added at 04:30 PM ---------- Previous post was at 04:27 PM ---------- Like i stated metering head not unit so you want me to send you the airbox to and fuel reg cheddarcheese said: hey mate revived the part today but why have i only received the flap part of the metering head what about the part that the fuel and injector lines connect to! Like you have pictured? For £40 quid i would expect the hole metering unit also http://the-corrado.net/showthread.php?55891-metering-head Quote Share this post Link to post Share on other sites
cheddarcheese 0 Posted May 16, 2011 (edited) you have pm no i dont expect the airbox the fuel regulator is part of the metering head and is sold together as one unit and at £40 this is usually what you get at that price. the part you sent me is worth a lot less on its own if you could send me the fuel regulator this would solve this situation? Edited May 16, 2011 by cheddarcheese Quote Share this post Link to post Share on other sites
VeeDub_NZ 0 Posted May 16, 2011 Does this car have the wider front wings? I.e. will the drivers wing match my passenger one on my 1990 16v? Quote Share this post Link to post Share on other sites
hunty 10 Posted May 16, 2011 its the 16valve 1992 standard wings so id amagine so Quote Share this post Link to post Share on other sites
nath.b 0 Posted May 19, 2011 Hello Do you have the coil amp module? If so I will take. Cheers Nath Quote Share this post Link to post Share on other sites
