Marshall936 0 Posted May 9, 2011 Well i think its safe to say i've been a right plonker! I went and got a low profile tyre fitted to one of my new alloys, which now clear the suspension which is good...Although I tried to remove it again it won't budge!!! Think its stuck on the 'ring' which protrudes from the brake/hub and slots into the centre of the alloy. Any ideas? I'd appreciate any help at all as i'm mythed on how i'm going to get it off :( Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 9, 2011 Soft mallet time- give it a good old whacking. Work your way around the rim. Quote Share this post Link to post Share on other sites
carrots 1 Posted May 9, 2011 give it a kick,then put a bit of copper grease on the hub so it dont stick in the future Quote Share this post Link to post Share on other sites
hendrikbmx 0 Posted May 9, 2011 jump, kick with one leg then immediately with the other. Quote Share this post Link to post Share on other sites
Jim 2 Posted May 9, 2011 Just make sure it's not on the "widowmaker" standard toolkit jack before you start doing any of this!! Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 9, 2011 ...then use some harsh language. Should do the trick. ---------- Post added at 08:27 PM ---------- Previous post was at 08:26 PM ---------- :lol: @ widowmaker! Good point Jim- good trolley jack and stands is a must! Quote Share this post Link to post Share on other sites
VR6 0 Posted May 9, 2011 ......... give it a good old whacking. Work your way around the rim. The old me would have made a joke about that. Quote Share this post Link to post Share on other sites
Swompy 0 Posted May 9, 2011 The old me would have made a joke about that. Was thinking the same thing but too tiered for it at the mo :D Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted May 9, 2011 give it a good old whacking.. Was thinking the same thing but too tiered for it at the mo :D :elephant: Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 9, 2011 Haha love the suggestions of drop kicking!! but i've tried with a mallet and a decent jack of the trolley variety, no luck as i can't get a good enough swing so think i need to get it to a garage on a ramp :( Heres the offending wheel centre: Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted May 9, 2011 you need to undo the bolts first. HTH. Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 9, 2011 lol took the pic after i put them back in :) Quote Share this post Link to post Share on other sites
VR6 0 Posted May 9, 2011 Have you tried lubing your rim? Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 11, 2011 Lol ^^^ I've just been told something called a sprocket puller may do the trick??? Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2011 you could try heating the rim up with a hot air gun? alloy expands at a different rate to steel so should just fall off if you get it hot enough. Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 11, 2011 Good idea, although problem solved now!!!! Found my mini sledge hammer so only took 20 mins and she was free!! Off to get some Lube now ;) Quote Share this post Link to post Share on other sites
weetos 0 Posted May 11, 2011 have your wheels had fresh paint?? the extra thickness of new paint may have done it Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2011 have your wheels had fresh paint?? the extra thickness of new paint may have done it I'll second that, take a wire brush to the hub before you re-attach the wheel, get off all the surface rust/imperfections then grease it up with copper grease or something. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 11, 2011 i have found a way of levering them off from the rear with a long bar and positioned correctly on the wishbones/subframe, didn't like hitting my new wheels with a mallet :lol: Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 11, 2011 Yeah they're freshly painted but i think its because they came from an MG? Think a bit of grinding and copper grease will be hopefully be enough! Quote Share this post Link to post Share on other sites
