stu37 0 Posted May 24, 2011 Hi guys just wondering if anyone else has noticed excessive side to side play in your front seats? Im not sure if the seats are on nylon type rollers and they have disintegrated? Any ideas guys? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted May 24, 2011 that's exactly what's happened.. replacements are about £6 for the pair.. for some reason £2 outer £4 inner! Quote Share this post Link to post Share on other sites
classic 0 Posted May 24, 2011 i got abit of play in my front seats, would quite like to sort it out. Bristolbaron, is it hard to change these nylon roller things? and would it be possible to get the part numbers? Quote Share this post Link to post Share on other sites
mimjed 0 Posted May 24, 2011 they are straight forward to change. just slide the seat out of the rail and swap them for the new ones. not sure of part numbers but tps will know what you mean. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted May 24, 2011 They're not rollers as such though guys, more a like a nylon guide that holds the slider in it's runner. This is the sort of thing you need... http://cgi.ebay.co.uk/VW-GOLF-MK1-MK2-MK3-GTI-SEAT-CLIP-GUIDE-C66-/190509681032?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c5b430988#ht_2149wt_689 Mark. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted May 24, 2011 Part no's are 191881213 & 171881213B.. As above they're not rollers, really easy to change - remove the seat by undoing the nut & allen key bolt at the front, slide the seat out to the rear. Remove old runners, fit new ones, slide seat back in. Its less than 5 minutes work per side once you know what you're doing! Look here for part no's and diagram.. http://www.vagcat.com/epc/ Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 24, 2011 Yep - clean and regrease the rails too - will be like new again! Quote Share this post Link to post Share on other sites
classic 0 Posted May 24, 2011 ah awesome, thanks alot. Quote Share this post Link to post Share on other sites
stu37 0 Posted May 27, 2011 Thanks guys for the posts will be on it asap as my sits you can literally shake if you get hold of them! Many thanks!!! ---------- Post added at 11:11 AM ---------- Previous post was at 10:55 AM ---------- Just as a heads up guys two sets enough for BOTH seats £4.50 posted on ebay BARGAIN!!! http://cgi.ebay.co.uk/VW-RANGE-INCL-GOLF-SEAT-CLIP-SET-INNER-AND-OUTER-NEW-/170596535221?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D5%26po%3DLVI%26ps%3D63%26clkid%3D220374657745450678 Quote Share this post Link to post Share on other sites
boost monkey 0 Posted May 27, 2011 my golf seat won't lock in properly when I slide it fully back (after the missus has been driving!) so i'm thinking about maybe doing this and definitely greasing the rails and cleaning them up. Quote Share this post Link to post Share on other sites
