chrishill 0 Posted March 3, 2004 I'm going to get myself a replacement panel filter, but i've read loads of post where people have been sent the wrong ones, so does anyone have the right part number for a 1990 1.8 16v? also, i know i've seen this on another post, does anyone have any more info on how to correctly drill the airbox? pictures would be good :D Quote Share this post Link to post Share on other sites
Jim 2 Posted March 3, 2004 Your wish is my command. One airbox modification guide, courtesy of Kevin Finlay from the Scottish Region of the CCGB. Quote Share this post Link to post Share on other sites
chrishill 0 Posted March 3, 2004 nice one mate thanks! Quote Share this post Link to post Share on other sites
bigben 0 Posted March 4, 2004 dont drill the air box get a proper induction kit for it they are bout £75 and made by piperX best move i made and works better than the drilled air box!! Quote Share this post Link to post Share on other sites
flusted 0 Posted March 4, 2004 bigben said: dont drill the air box get a proper induction kit for it they are bout £75 and made by piperX best move i made and works better than the drilled air box!! Dont these suck in unwanted hot air from engine? If you drill you box,do it wing side only and run a cold feed of air from behind the grill and you will notice the difference Quote Share this post Link to post Share on other sites
Henny 0 Posted March 4, 2004 bigben said: dont drill the air box get a proper induction kit for it they are bout £75 and made by piperX best move i made and works better than the drilled air box!! You can't get an induction kit for a 1.8 16V! They're K-Jetronic and as such you have to keep the airbox as that's also the metering head! :roll: Stick with a K&N and a few well drilled holes and you'll get a slight increase in responsiveness and a slightly nicer engine note... 8) I tried to post this last night, but the server had gone down... Quote Share this post Link to post Share on other sites
kvwloon 0 Posted March 4, 2004 I'd recommend the airbox drilling mate, sounds much better, but dont go too overboard with drilling the holes, put some in , give it a blat, and see what you think. You can always put more in if you like. Take a look at the 'Embarrasing Drilled Airbox' thread before you make your airbox like a Swiss cheese. I'd still drill the airbox, just not excessively! Quote Share this post Link to post Share on other sites
RobyD 0 Posted March 4, 2004 bigben said: dont drill the air box get a proper induction kit for it they are bout £75 and made by piperX best move i made and works better than the drilled air box!! Think i saw one of these on ebay. It looked like it was just a normal 16v metering head upper part with pipercross foam cradle on the bottom. Think the foam was all round therefore exposed to the engine side as well? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 4, 2004 RobyD said: bigben said: dont drill the air box get a proper induction kit for it they are bout £75 and made by piperX best move i made and works better than the drilled air box!! Think i saw one of these on ebay. It looked like it was just a normal 16v metering head upper part with pipercross foam cradle on the bottom. Think the foam was all round therefore exposed to the engine side as well? Yup, they're mainly for the 2.0 16Vs though, not the KR 1.8s... They don't filter as well as a K&N panel will 'cos they're foam which will lead to increased engine wear... :? Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 4, 2004 chrishill said: I'm going to get myself a replacement panel filter, but i've read loads of post where people have been sent the wrong ones, so does anyone have the right part number for a 1990 1.8 16v? ... same as for a late model golf 2 16v (89 on I think), i.e. the bigger, wider sized 16v air filter, my Jetex Response panel filter was ordered from Motech as a late golf2 16v item and was fine on my November 1990 1.8 16v David. Quote Share this post Link to post Share on other sites
chrishill 0 Posted March 4, 2004 :D how good are demon tweaks? ordered the filter yesterday afternoon and it was waiting for me when i got home from work tonight! thats well fast in my book! Quote Share this post Link to post Share on other sites
chrishill 0 Posted March 6, 2004 just been and done it, my god! the noise is fantastic, the engines always had a bit of a whistle, the combined with my exhaust and the induction sound..... :twisted: BWWWARPP WEEEEEE BRRRRRRAP! :shock: Quote Share this post Link to post Share on other sites
fry 0 Posted March 16, 2004 You can't get an induction kit for a 1.8 16V! They're K-Jetronic and as such you have to keep the airbox as that's also the metering head! : stroeve motorsport do an induction kit for the 1.8. it is essentially a cone filter with a heat sheild on the engine side and fits under the fuel injection stuff where the air box is at the moment. Quote Share this post Link to post Share on other sites
