kvwloon
16v KR engine - Oil staining on air filter!
Every time i change the air filter on my 16v KR engine C, there is oil staining on the air filter element, not a large amount at all, but apparently caused by small oil drip from above the filter element! Should i be concerned? Thanks in advance all.
that will be from the oil breather pipe,unless you got loads of oil coming out of it i wouldnt worry about it
