rodmax
Breaking Red 16 v corrado
Hi ,have added some more parts to the list (and adjusted the orig list)
Thanks rod
Hi,some one else has shown interest in the wing.i will give them a day or so ,if not its yours
Thanks rod
is the drivers side door still available...plus would you know if its the same door for a 2.0 16v.?...already bought one door but its not the right fit
cheers
rachw
Hi yes & yes. i will check tomo about the door & get back to you.Yes i still have the calipers ,they are not that old as i have reciepts in the history file,for when they were replaced.
I'm around this weekend if you wanted to pick up.
let me know rod
Hi i've checked the door will fit,it's in great condition,how complete do you want it
thanks rod
re drivers door:- as complete as i can have it if poss (glass,mirror.handles etc) i do have the door card from the original door
many thanks
rachw
Hi, A few parts are still left ,before it goes off for scrap. so prices reduced,
Give me a shout. thanks rod
Any takers for the bits that are left.before it goes off for scrap. I have also been offered another corrado so i may have another one to poss break. will know by the the weekend
Thanks rod
Hi Rod, do you have the 2 bump stops that screw into the slam panel the bonnet presses against when closed?
Also a pair of early golf T shaped door lock pins in good conditon, only small bits i know!
Kip
