mattyattitude 10 Posted June 29, 2011 my dipped and main beam have all stopped working :( ive checked all the fuses inside the fuse box and on the uprated wiring room,,, they were all working one day and next they were temprmental then they just didnt work at all any other ideas?? Quote Share this post Link to post Share on other sites
domwells27 0 Posted June 29, 2011 Have you checked the relays on the uprated loom? water ingress can lead to problems. Could also be the switch Quote Share this post Link to post Share on other sites
quicky1980 0 Posted June 29, 2011 as above, probably the relays. I had the same issue driving at night where the beams were on off randomly until finally giving way the next day. You can take them apart to check, but suggest you simply replace, dead cheap and easy Quote Share this post Link to post Share on other sites
