Roger Blassberg
Radiator temperature switch
ruler? :)
it's 32mm I think, but I've always used an adjustable spanner as I can't justify a deep 32mm socket only for that.
Thanks David. It's just that it seems as though the hexagon is rather shallow and close to the face of the radiator.
(You are quite right of course about "Being a Boy Scout", about this and measuring it myself).
Best wishes
RB
To put this to bed, it's 29mm. And not at all tightly done up (which should have been obvious to me if I had thought about it - screwed as it is into a very flimsy radiator shell). All is well again for the princely sum of £12.
Best wishes
RB
It's an imperial size - think plumbing!
1" 1/8th IIRC
All the oil filter housing and sensor fittings on VW's are also imperial
hope you put some sealer on the thread , i didnt, mine is tight but is leakin coolant . Will be doing it next week .
  Roger Blassberg said:
Don't know, I used a borrowed 30mm socket which was fine for the minimal torque needed.
Best wishes
RB
Believe its a 29mm size. Torque 35Nm.
If it doesn't come with a fibre washer fitted, then N 043 808 3 should do the trick.
