mossy1000
g60 possible icv!?
hi need abit of help not sure if it's the icv or something else but my g60 is struggling at the moment it doesn't idle properly, only starts if i use the accelerator, when driving it keeps on losing power and back firing then picks back up, my friend thinks its definatly the icv just want to know other opinions before spending the money on one, hope someone can help.
have you checked the crank pulley timing marks as that is the exact symptoms i had and the pulley was really worn throwing the timing out
Id check timing too.
Ive got a couple of isv's that can be for sale if needs be. Will have an ecu relay too.
