Ginger60 0 Posted July 19, 2011 My heated water jets device has corroded to oblivion, any tips on replacing this? Also the switch that does the operation is nigh terminal... Quote Share this post Link to post Share on other sites
t700bes 1 Posted July 19, 2011 I know I have them, but I have never used them, and when I did the engine conversion, i didn't plug them in... I know they are the same on a Mk3 Golf Gti if that is of any help.. maybe you could find the stuff at a scrappy! Quote Share this post Link to post Share on other sites
Ginger60 0 Posted July 19, 2011 I know I have them, but I have never used them, and when I did the engine conversion, i didn't plug them in... I know they are the same on a Mk3 Golf Gti if that is of any help.. maybe you could find the stuff at a scrappy! really mate thats awsome ok ill have a ganders cheers ;o) Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted July 20, 2011 Where is the switch located for them mine had them but could never find the switch ?? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 20, 2011 They're either automatic, based on the outside temp (sure it says that in the manual), or work off the heated rear window switch like the mirros do. Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 20, 2011 just work off the heated rear window switch/circuit AFAIK you could fork out for a new heated one from VW (probably best part of 40 quid by now), repair the corroded connector (it's usually just the +ve side that corrodes) so you can make 1 good one out of 2 corroded ones or just put very strong windscreen wash in the bottle in the winter most second hand ones will be equally manky unless the owner has hardly ever used the HRW, always remembered to switch it off after a minute or so or already replaced an original jet. Quote Share this post Link to post Share on other sites
Ginger60 0 Posted July 20, 2011 ok new one it is? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 20, 2011 I've not run heated jets for years - just buy 2 non heated ones from VW - £5 the pair As long as you use a decent screenwash then they'll never freeze apart from in snow when the heated ones won't be any better Quote Share this post Link to post Share on other sites
