Alex_G60_Fanatic
Head Unit has no power....
Tried turning my radio on the other day in the rado and there is no power getting to the head unit. I looked at the fuse box and that all looks fine.
The only thing that I've done to the electrics since I last used the radio is fit an external up-rated headlight loom and change the battery.
I had the head unit out to check the back of it and I did find a loose wire...
[ATTACH=CONFIG]48371[/ATTACH] [ATTACH=CONFIG]48372[/ATTACH] [ATTACH=CONFIG]48373[/ATTACH]
does this have anything to do with my problem do you think?
The only power carrying cables are:
Red - permanent live
yellow - ignition live
black - earth
have you checked the fuse on the back of the head unit (silly question i know).
the two in you photos look like outputs for something maybe sub/electric aerial
Hey Alex, As above you only need 3 wires (2 really but one is ignition)
All the others are extra...
Multimeter is gonna be the only way... Brown / Black earth Red is ignition and yellow is permament live.
So yellow only goes live when the ignition is on..
Sorry If you know all this already :)
