robo22sri
HU loom pic?
Has anyone got a pic of the HU loom wiring?
mine has had the speaker cables all cut off! and re joined and the original smaller block for the power has 2 cables left in it and the rest joined!
the stero is always on live and doesnt have a ignition switch live argh!!
cheers Rob
any one know what the blue with a white strip is for?? it is with the power cables in the black block!
i have worked out that the red with a white strip is the 12v live, brown is the ground, blue with a grey strip is the dimmer?!?
i am talking from memory, so might not be 100%..
On one connector block are the power and control lines...
Blue/white is the remote - its supposed to go to 12v when the stereo is on.
Yellow is the perm live
Red is ignition live
Brown is earth
there is a dimmer one on there too
The other block should then have pairs of speaker wires that sort of match ie purple and purple\white stripe for each of the 4 corners..
That is from memory - i havent been behind the head unit recently so I'd deffinatelt just get in about it with a multimeter!
