neil20vtc
electric recaros not tilting
just fitted the recaros out of my old corrado into my mk2 golf, when fitted in the rado all the switches worked but upon fitting them in my mk2 (albeit a few years later) the drivers seat electic tilt function doesnt work i tried swapping it for the slide switch which was working but no joy also sprayed the plugs with some isopropyl spray still nothing any ideas?
The circuit is fairly simple. Puts 12 volts across the motor which is what the switch does.
So either one of the two wires is internally broken or the electric motor is goosed.
Is this a VW seat or other?
If VW, the wires should be orange and grey, including the T-offs from the height adjustment switch which supply the power to the backrest adjustment switch.
Check the interconnecting wires between the two switches are OK, then line check or voltage check the orange & grey to the backrest adjustment motor.
Doesn't matter which way 12 volts is applied, the switch reverses the supply to get direction movement.
