vw_john
Removing Injectors
Im going to get my injectors balanced/cleaned/pressure tested. (g60) how do i remove them. is it as simple as taking them out? i read something about unplugging the fuse for the fuel rail?
any help would be appreciated, cheers!
just did this on mine
you need the isv off and out the way , fuel pipe and connector off the driver side of the rail , fuel pipes off the pressure reg , and unbolt the reg
then its 2 bolts that hold the rail down , you should then be able to wiggle the wiring loom/inj/rail out in one piece ...possibly have to unplug the inj once theyre pulled free
take a look at the inj wiring as it gets brittle
I unplugged the battery and did the same thing, although i wish it was as simple as
i just pulled um out
they were tricky *******s
right, i wish i had read that first... i have unplugged/screwed so many things! haha.
lol must be differant on 16v
you got it easy then lol
