Tristan H 10 Posted September 12, 2011 Hi all , I was test driving a '95 16v the weekend , and for the duration and while left ticking over the water temp stayed at 70degrees . The engine is all standard , and the fan wasn't running . Surely this is a bit low? Quote Share this post Link to post Share on other sites
corradophil 3 Posted September 12, 2011 IIRC the thermostat should open at 87 deg C, so it could be just a case of the thermostat nor closing. Mine has a OEM ABF thermostat at the moment which opens at 82 deg C, but I am finding it takes a long time to reach that. Quote Share this post Link to post Share on other sites
Andy G-iR 10 Posted September 14, 2011 yea when mine was on the road used to run pretty low unless u really gave it some or had jus been drivin quite a while and even then werent that hot Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 14, 2011 I don't think they get that hot until they are driven hard as mentioned. That has been my experience with the 2 in our family. Well, 1 and a half ^_^ Quote Share this post Link to post Share on other sites
Tristan H 10 Posted September 14, 2011 Think I'll drop in an ABF stat so , just to be sure . Quote Share this post Link to post Share on other sites
corradophil 3 Posted September 14, 2011 A genuiine ABF thermostat will make it run cooler, if you want it to be hotter get one for the 9A. Quote Share this post Link to post Share on other sites
Tristan H 10 Posted September 14, 2011 hmm... just the gauge showing 70 had me perplexed... can't help fuel economy? Quote Share this post Link to post Share on other sites
corradophil 3 Posted September 14, 2011 It's not good if the engine is not reaching normal temperature. With an ABF thermostat (genuine VW ones anyway) the engine will run cooler than with a thermostat for a 9A. So I would recommend getting one for a 9A, which should be the engine code for your engine. The ABF was fitted to Mk3 Golfs. Quote Share this post Link to post Share on other sites
Tristan H 10 Posted September 15, 2011 cool , I'll try that so. Quote Share this post Link to post Share on other sites
