dave_c 10 Posted September 13, 2011 My active spoiler has never worked. It works off the switch but not at 45mph etc. My MPG gauge reads a constant 99.9MPG. The speed reading on the MFA display reads random numbers irrelevent of the actual speed the car is going. It seems to just read higher the longr I've been driving. Any ideas? I've tried searching but theres so much about the blue wire etc etc Is this speed sensor related? If so where is that? Quote Share this post Link to post Share on other sites
eurospec 10 Posted September 13, 2011 I had the same problems with mine. I ended up replacing the clocks with another set, but kept my original speedometer to keep the mileage the same, and ever since then everything has worked spot on! I also replaced all the vacuum hoses apart from the one to the ECU. Quote Share this post Link to post Share on other sites
rodmax 0 Posted September 13, 2011 Hi what type of corrado do you have .i may be able to help let me know ,rod Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 14, 2011 1990 1.8 16v cheers Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 14, 2011 If it's anything like the MK2, then there's a speed sensor on the back of the clocks. Not sure if it's a replaceable item, or whether you need to replace the clocks - it'll be clearer once you remove the clocks Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 14, 2011 All I have is a vacuum sensor on the back... unless its located behind the dials? Quote Share this post Link to post Share on other sites
rodmax 0 Posted September 14, 2011 I have a set of clocks from a 1990 16v. you can have them for £25 inc the postage if that's of use to you ,let me know thanks rod Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 14, 2011 Is there any way to check if mine are at fault? If I buy a new set and these are also duff then I'm none the wiser! Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 14, 2011 Do you get valid readings for distance travelled and average speed on the MFA? These are also calculated using the reading from the speed sensor. Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 15, 2011 Im not really sure if they are working correctly! I'll have a lite investigation and come back to you. Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 20, 2011 I fitted a new gauge cluster and now all of the mfa functions work! Spoiler still doesn't work automatically though! However, on the way home tonight (before I fitted the new gauges) it started working on it's own! It went up and down twice before failing to come back up again! Any ideas where the fault lies? Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 24, 2011 Still none the wiser! It's worked a few times now but still randomly stops! Loose connection? Broken wire? Where are the main bits I should look for? Quote Share this post Link to post Share on other sites
owen g60 10 Posted September 24, 2011 if your clock issue is now fixed i would suspect that the spoiler module is at fault. You can find it by removing the facia odd your clocks and removing the drivers heater module... it is a small black box clipped to the inside of the dash where the spoiler switch is located Quote Share this post Link to post Share on other sites
dave_c 10 Posted September 25, 2011 Thanks I'll have a look later! I guess the only option is to replace it? Quote Share this post Link to post Share on other sites
TimDoc 0 Posted September 25, 2011 depending on the module code i may have one. PM me if you get to that point! Tim Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 26, 2011 (edited) Intermittent functioning screams 'broken connection' to me - either in the wiring or the spoiler module itself. Check the wiring into the module first - this last bit could be a cheap fix.. I think according to the Bentley manual the speed input into the module comes in on pin 8. Edited September 26, 2011 by tony_ack Quote Share this post Link to post Share on other sites
