d3927
Corrado clutch slave cylinder
Hello- does anyone know how to change the clutch slave cylinder, does it simply come out after removing 2 retaining bolts and hose?
Yeah it's pretty easy, be very careful when pulling the old one out though because the if the rubber boot is broken the rod can fall into the bell housing and then you have to remove the box!
