Boydy
Upper Rad Neck / Union Plug
Hi, hoping someone can help with this. My VR6 is currently sitting in a garage where it is having a samco hose kit fitted along with a new radiator. Unfortunately the upper rad neck hose / union plug that bolts onto the top of the radiator and attaches to the coolant hose is extremely brittle and cannot be re-used. I have found a new replacement but that will take about 2 wks to get here from Germany, plus such is the bad timing as I have a flight booked to leave the country on the 17th. So I need it asap.
Cheers, Boydy
Thanks for letting me know Tim but shortly after posting I found a TIG weilded Billet replacement from gruvenparts.com. ive managed to get through and place an order about 40 mins ago and it should be here by monday at the latest. Thanks again, appreciate your help
