robrado974
Window problem and door pin plastics pics needed please
Hello .Its winter time when i always sort out those little things that annoy . First up is my drivers side window , i have another one to replace mine which is scratched , but when you press the button to send the window down it stops with around 50mm to go ?. I cant see anything stopping it , any ideas please . The other thing i need to sort out is a pic of the plastic part which the door rods connect to so i get them in the right way . Kind regards Rob
When my window did that, it was because the door handle central locking cable wasn't routed properly. It gets looped around the bottom of the window and that stops it moving fully. At the very bottom of its travel, does the front go down more than the back? (it's really obvious if this is happening because the whole glass pane twists in the door).
You may need a new door handle - the window chafed my cable so severely it exposed all three switch wires, which then rubbed together under vibration and made the doors randomly lock as you were driving along. Sadly you can't get deep enough in the handle to replace just the cable. Replaced the handle - no more problems.
Stone
