Tunerkid07 10 Posted October 11, 2011 I am removing the air conditioning out of my '90 G60, I was just wondering when the compressor is removed if a bracket and pulley is needed to keep the stock position of the belt so there is no interference or if I could just run a shorter belt and everything be fine? Thanks Quote Share this post Link to post Share on other sites
fla 9 Posted October 11, 2011 on the vr you use a shorter belt, i would assume the same in G60. Quote Share this post Link to post Share on other sites
