C-mann
Lambda probe
My VR6 requires a new Lambda Probe due to the revs being erratic.
Can anyone tell me how hard it is to replace one???
Has it been confirmed as dead by testing with a voltmeter? You don't erractic revs from a dead lambda on the VR, it just runs a bit rich....as confirmed by disconnecting mine.
Replacing it is fair simple but space is tight down there and you need to be careful not to snap the wires by spinning them round on themselves too many times and the metal heatshielding makes that quite tricky. Can't remember the spanner size but that can be worked out from the new one.
K
I put my VR6 into a VW Garage and that is what they came back with. Although we all know what garages are like thats why I posted the message.
I did try resetting the ECU by disconnecting the battery and leaving it for 15mins, but it had no affect!
fitting a new one is easy....just like undoing a bolt (almost)...cut the wires off and use a socket to undo...i found a cheep oem one on ebay.com
I have seen 'genuine' ones at ECP for £70. That's close to the parts club price which I presume is +VAT
