Furno 0 Posted November 20, 2011 Got the MOT tomorrow so thought I'd check simple stuff like lights. One of the front fog lights isn't working. Its not the bulb, I've replaced them and swapped them around etc......... Eventually traced all wires back to connector plugs, the drivers side wire runs across the front of the rad and plugs into the connector (2 pin), but the passenger side doesn't plug into anything, its just got an unconnected 2 pin plug on the end. This explains why one of the fogs didn't work. Swapped em over and it makes the other light work, so it looks as though I'm a connection to the loom missing!!! Where is it? Should the drivers side wire run across the front of the car, or is it that one thats missing??? Can someone have a look to see where the 2 plugs plug into the wiring loom. Thanks. '95 VR6. I'll try to post a photo. Steve Quote Share this post Link to post Share on other sites
dragon green 4 Posted November 20, 2011 Near the battery on a valver ! (mine anyway) Quote Share this post Link to post Share on other sites
Furno 0 Posted November 20, 2011 That's the connector I've got - where's the other one for the drivers side? Thanks. Quote Share this post Link to post Share on other sites
dragon green 4 Posted November 20, 2011 mines just behind the foglight, and the lead is just coiled behind the foglight ! makes it really easy to take the foglight off. Does your outside temp work ? i believe the plugs are the same, just an idea Quote Share this post Link to post Share on other sites
Furno 0 Posted November 20, 2011 Photo attached. Quote Share this post Link to post Share on other sites
Furno 0 Posted November 20, 2011 Brilliant - found the plug down by the temp sensor. All sorted now - thanks a lot. Don't you just love these forums - where else would you get instant help on a Sunday afternoon, thanks again. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 20, 2011 Are fogs tested on the MOT? Quote Share this post Link to post Share on other sites
