trigger83
pic request
aqua blue or any corrado with rh zw1's on. just bought some and would like so pics if any1s got any. thanks
Where did you get yours from bud?
I got mine of ebay germany too, if you check out my build thread I should the before and after work.
iirc spacer are 20 and 30mm and the wheels are 8", 215 wide tyres but could be wrong so will try and check for you. What corrado are they being fitted to? Mine is 16v rear beam and vr6 fronts
I'll get some pics put up as soon as i get chance to fit em. goin on my vr6,got some 25mm adaptors all round. what size tyres u runnin?
zw1 as standard are et60 so yor 25mm spacers would give you et35.
Im et30 (20mm ZW & 10 H&R mm spacers) and et35 (25mm ZW spacer). 205/40/17 Falken Ziex ZE-912tyres with 8" rims, no trouble with rubbing but I have rolled the arches.
any idea what spigot rings u have and what the centre bore of the zw1's is? im looking on ebay @the mo checkin out 72.1,but just wanted 2 check
