cunningfox69 10 Posted December 10, 2011 Hi, can anyone tell me where the comfort control module is located? Thanks Quote Share this post Link to post Share on other sites
RW1 0 Posted December 10, 2011 Doesn't really exist on the '94 VR6 or any other. What are you trying to find function wise? . Quote Share this post Link to post Share on other sites
boost monkey 0 Posted December 10, 2011 For the electric window and central locking control module, it's behind the offside rear doorcard IIRC. Quote Share this post Link to post Share on other sites
cunningfox69 10 Posted December 11, 2011 Thanks Boost Monkey, RW1 i'm trying to work out why my central locking only locks and won't unlock (see other post), i've checked everything else out and i want to check it to see if its faulty Quote Share this post Link to post Share on other sites
swiftkid 1 Posted December 11, 2011 Is it off the key or an aftermarket remote central locking? You'll probably find one of the wires going to the door handle has broken or has a ganky connection. If you unplug the connector in the door and put a wire across the connector, can't remember which ones but you have a live and a lock/unlock signal, then it should lock and unlock. If it doesn't you can rule out the handle. Quote Share this post Link to post Share on other sites
cunningfox69 10 Posted December 12, 2011 Nice one Swiftkid, i'll give it a go Quote Share this post Link to post Share on other sites
