vw_john
best chip for g60?
Also, what are the uprated injectors you all get? my girlfriends dad deals with injectors and I need to know what ones are the best? after I have them what chip should I get for a g60 with stage 4 charger, RSR outlet, de-cat, 68mm pulley?
regards
We can supply you a chip for your ECU that will compliment the mods on your G60. We have specialised in Corrado since 1994 and carry all manner of tuning works, in addition to the routine maintenance. Please feel free to contact me at work Mon to Fri 01903718684. I look forward to hearing from you. Regards, John. JMR
Edited by 16VG60
sns are popular , alot of folk use the red 30lb ford mustang injectors, you dont really need uprated inj for your spec
im using a 40euro ebay.de chip ...happy with it
I just fitted an sns chip and 3.5bar fpr, 100 times better than the jabba chip that came out!!
You wont need injectors unless theres more done to your engine that you havent listed.
If its not going to cost you anything might as well get them referb/cleaned
If John is close to you i would go with John,aswell as the chip he'll be able to set up your engine to make the most of it!
Edited by PaudieG60
