Johnny H
Key fob not working after taking battery off??
Hi Guys
I took the battery off today to upgrade the headlight loom and after putting it all back together now the key fob won't work the car.
Anyone got any ideas??
Thanks Johnny
  Jon_vr6 said:
Which alarm mate?
Have you tried holding the button down on the fob...
It's a scorpion and I have tried holding it for a bit and tried holding both buttons together
Is the bat ok in your fob? What about your 12V?
As you were (no doubt) testing your lights you might need to throw some charge into your 12V.
Edited by tentonhammer
As you were (no doubt) testing your lights you might need to through some charge into your 12V.
The bats are ok in both, 12v is only a few months old and the fobs are fine aswel.
I've just found out that I've got a key for the alarm, will this help??
  tentonhammer said:
Can you actually get in to the car - are you locked out?
Yeah I can get in and drive it, I just can't use the fob to lock or unlock the car.
---------- Post added at 09:18 PM ---------- Previous post was at 09:15 PM ----------
  Toohottotrot said:
Did you try the key switch
Sounds like a fuse to me
No not yet, hoping to have a go tomorrow mate.
Fuse?? Where will it be? I'll have a look and see if it's blown
Well Thank you guys for all your help cause I've fixed it today.
This is what I did:-
a) Disconnected battery for 1 hour.
b) Turn Ignition ON.
c) Reconnect battery.
d) Turn ignition OFF.
e) Press remote control for 10 seconds.
Worked first time for me.
Thanks again guys.
Johnny
Edited by Johnny H
