floppyman
Another electric window problem..... So I tought
Today when coming from work I noticed my passenger window wasnt working!!! I could hear the relays clicking about but nothing.
Later I went again in to the car to investigate......
Check electric mirrors.... GOOD
Check sunroof... NOT GOOD
Ive pushed the button to tilt it open but nothing, then I pulled it to close and it moved... Tryed again and sunroof back to normal....
Should I try the window again?? And so I did and everything back to normal.
Im good with electrics but this one I just cant explain. Anyone have any thoughts?
I dont know if the sunroof is controlled from the window control unit, but if it is then a poor connection/wiring fault with the input/unit itself then that could account for both being intermittent. :scratch: I'm sure someone will have a definitive answer to that. If its not the window control unit, then the only option is to chase the wiring back and look for any problems.
