cptkirk 10 Posted February 18, 2012 as above..ive got 215's on the front..will 225 fit on the rear? Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted February 18, 2012 size of wheel...? et...? how low is the car...? Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 18, 2012 sorry...ET40..not lowered yet...tyre size 225/45/17 Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted February 18, 2012 Dependant on the wheel width they will fit but look a bit big. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 18, 2012 They're massive!! Why the hell would you want to fit those?? Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 18, 2012 I have 215 on the front 225 on the rear. it will scrape if you try very very hard.....and my car is low. I think my offset is 38 & the rims are 8" be careful they dont catch your suspension. ---------- Post added at 11:53 AM ---------- Previous post was at 11:50 AM ---------- ooops no I dont! I have 205 & 215s.... so yeah 225 is quite wide for a C Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 18, 2012 wont fit and will rub, been there years ago when i bought some audi comps and thought Mmmmm will they fit straight on, the answer was no. Quote Share this post Link to post Share on other sites
OSV 0 Posted February 18, 2012 width x profile = hell no Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 18, 2012 pmsl..love some of the comments here.. ive got some 215/45/17 on now..put the rims on and im very happy..miles better than the 15's it had before..ill get pics on tomorrow.. with the et40 offset and 215's..can i still lower it 30 mm Quote Share this post Link to post Share on other sites
OSV 0 Posted February 18, 2012 rolling radius is wrong to keep within tolerance of original need 205/40 or 215/35 Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 19, 2012 (edited) will it make a big differance with the vec..it had 55/16s..with every inch extra with the rim you take it off the tyrewall... so 55/16's to 45/17's Edited February 19, 2012 by cptkirk Quote Share this post Link to post Share on other sites
OSV 0 Posted February 19, 2012 Corrado 15=50 16=45 17=40 in the same way but with tyre wall as a % of width going wider has an impact too Quote Share this post Link to post Share on other sites
Grim1 1 Posted February 19, 2012 The aspect ratio (or profile) is a percentage of the tyre width. So, for a tyre size 205/50 R15, the 50 (aspect ratio) would work out as about 102.5mm - 50% of the width. So, as standard, fitting a 17" rim, you'd fit tyre size 205/40 R17. To fit a tyre with a greater overall width, you would then need to reduce the aspect ratio in order to keep the rolling circumference similar to OE spec. So, in theory, to fit a tyre with a 225 width, you should really reduce aspect ratio to a '30', so 225/30r17. Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 19, 2012 ive now got 205's on the front not 215's still 45 profile...am i lookig at a small speedo difference or is it more than that Quote Share this post Link to post Share on other sites
Grim1 1 Posted February 21, 2012 It will cause the speedo to be out slightly. I'm fairly busy at the moment, but if I get time, I'll work out by what percentage, and off I can work out what your speedo will be saying at what speed. Quote Share this post Link to post Share on other sites
Grim1 1 Posted February 21, 2012 Right, I've had a look into this for you. Oe 195/50 R15 rolling circumference would be 1737mm (avg rc), 205/40 R17 rc=1796 (avg rc) and 215/40 R17 rc=1858 (avg rc). So, when comparing the 205/45R17 with 205/40 R17, the 205/45 r17 will have a greater rolling circumference of nearly 62mm, 3.4%. Normally, 3% would be the normal recommended maximum tolerance. Going by this, when your speedo reads 70mph, you are in fact travelling at 72.5mph. That said, the difference between the oe 195/50 R15 and a 205/40 R17 is about 3.44% or 59.7mm. Meaning that if you move straight to 205/40r17 from the 15", your speedo will read 70mph when you're actually doing 72.4mph. Hope that helps. Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 21, 2012 wow..im crap at maths lol....its not that big of as problem if were looking at a few mph....ive found that the 215's rub on the front so hopefuly the 205's wont..will find out at weekend. cheers for you input m8 Quote Share this post Link to post Share on other sites
mr.dG60 10 Posted February 21, 2012 This link makes it easy to see difference in tyre sizes. http://www.miata.net/garage/tirecalc.html Quote Share this post Link to post Share on other sites
Grim1 1 Posted February 21, 2012 To be honest, my first C had 17"s on and I ran in the 205/40 r17. Fitted a treat, and I found I got used to allowing for 2mph as and when I needed to. Its not a big difference between the 205/40 and 205/45. The figures I used were based on average rolling circumferences, but the difference between different tyre manufacturers dimensions can vary by a few millimetres, so you may find one brand fits perfectly and another is on fractionally too big. I always found Toyo Proxes T1R (or T1S) a good fit in a 205/40 R17, and my first C was slammed as low as possible at the front. Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 21, 2012 with the 215/45s on the front its rubbing on speed bumps on the top of the arch..ill swap um over torrow and see what the crack is..its getting lowered by 30mm min so i wanna make sure its fine.. cheers again Quote Share this post Link to post Share on other sites
cptkirk 10 Posted February 22, 2012 swapped um over and the fronts are fine..ive now got the 215's on the rear and there rubbing on the suspension leg..apart from getting 205's or spacers..is there any other way around it?? Quote Share this post Link to post Share on other sites
