NormanCoal
MK5 R32 engine, with MK4 R32 looms and ecu
Firstly, the mileage is under 10k (as I was told when I purchased), but I have no proof of this, nor have I heard the engine running – I believe the mileage claim to be true because of how clean the block is, but it is imperative that this is sold as seen as I cannot guarantee the mileage.
So, the remains of the MK5 loom was thrown away, and the MK4 versions fitted in their place. I have both pieces, along with the section that runs to the electronic pedal. I then fitted the block with all the MK4 ancillaries, to include the alternator bracket (so that a power steering pump can be fitted), alternator, aircon compressor, water hoses etc. I also purchased a brand new MK4 R32 fuel rail which is not fitted (this has a fuel return which the MK5 version does not)
As mentioned, I have all the wiring loom sections for the engine, the MK4 R32 ecu, with matching clocks and a single key, MK4 maf and inlet tube, lambda’s etc etc. There is no downpipe included, as the MK5 engine uses different manifolds and is not compatible with the MK4 downpipe.
As you can see in the pics, the OE oil/water exchanger has been removed in favour of a Mocal take-off plate (the engine was going to be fitted into a MK2, and when the front engine mount is fitted, there is no space for the OE setup. Also, the secondary air pump setup has been removed, but I may still have this somewhere, but for the purpose of this sale, please assume that it is not included.
There is no clutch or flywheel setup fitted or included in the sale (it was originally DSG)
The VR6 gearbox that is attached to the engine in the pics is an empty case and is not included in the sale.
I am located near Guildford, but the engine is stored in Bracknell.
Price is £1750
If for some bizarre reason someone doesn't take the whole lot as a package and the looms & ECU etc become available, I'd be very interested in taking them off your hands!
Thanks for the interest KADVR6 & FishWick - I hope not to be sending you a message about the loom and ecu, but you never know
Don't mean to pinch the thread, but I've got a brand new r32 ecu. Bub engine code if wanted?
If you are asking me, then thanks but I have no need at the moment
I'm after a MK4 one specifically mate, but thanks for the offer!
it is mk4 i believe. part number is 022 906 032 kg
would this not have been better via pm than on my thread? :)
The MK4 ECU part # ends in CP btw
im sorry man! thanks for the info and glwts!
