G60Dan
under bonnet sound proofing
Is the std under bonnet sound proofing still available? If so what sort of money is it?
Cheers
Dan
i started to strip mine off the other day as it looks a bit gash only to find it leaves a load of sticky hard to remove crap under there. woe is me. :cry:
same here,only did one section and that took me a few hours :x
Get a blow torch and wall paper scraper.
the trick is, to heat the knife, not the panel.
it'll slide through it.
get any remainging gunk off it with meths.
then polish it up.
i removed mine took about 2.5 hours. Get some chewing gum remover or tar and glue remover (same stuff really) apply it too one section at a time with a brush leave it too soak in for 5 min then use a filler spreder to scrape it off. Cover your engine bay tho you dont want bits of glue everwhere :D. the good thing with this is it dosnt fade,damage,take paint off. just needs a polish after :D Don't use thinners it makes a right mess i know i tried :wink:
ohhhhh LOL thats whats thats for ummm.... well i noticed no sound diffrence driving around with no bonet... oh well i willl still take mine of coz it's like half missing anyway...
