vr6paul 0 Posted March 31, 2004 My drivers chair has a habit of rocking now an again. It is as if one of the bolts at the back right hand side of the seat is worn/broken/missing. Anyone have any ideas of casue or hot to sort it? It is a bit un nerving when it lears forward and to the left going round some corners. Any help please cheers much guys Paul Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 31, 2004 Sounds like one of the white plastic guide clips is broken/missing. They're about 70p from the dealer. There's also a orangey/yellow 'buffer' at the front of the seat where the travel stop bolt is. Check those out. K Quote Share this post Link to post Share on other sites
vr6paul 0 Posted April 1, 2004 does the seat need to come out to fit guide clips? cheers Paul Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 1, 2004 Yeah.. fairly easy tho, remove the plastic covers from the guides then put the seat to its lowest setting, undo the bolt at the front and slide fwd to release Quote Share this post Link to post Share on other sites
Henny 0 Posted April 1, 2004 ...undo the bolt at the front and slide fwd to release Erm, Slide BACKWARDS to release the seat! :roll: :lol: Quote Share this post Link to post Share on other sites
VR6 0 Posted April 1, 2004 Maybe Supercharged meant that you should hold the chair in a static position and slide the car forwards ;) Quote Share this post Link to post Share on other sites
Henny 0 Posted April 1, 2004 Maybe Supercharged meant that you should hold the chair in a static position and slide the car forwards ;) Now that I gotta see... :D 8) :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 1, 2004 VR6 wrote: Maybe Supercharged meant that you should hold the chair in a static position and slide the car forwards Now that I gotta see... Guys... I stand facing the rear of the car and slide the seat forwards... :wink: ..or is that backwards :? Quote Share this post Link to post Share on other sites
