VWVW
Where does this engine part get attached to ?
Guys...Noticed this part was loose at one end and is flapping about in the engine bay. What is it and how should it be attached ? A picture would be ideal.
cheers
It clips onto the ABS pump. I'll see if I can get you a pic of mine so you can work out where it goes :)
I think it clips into the Allen key bolt hole you can see in the pic you posted.
put the top noggin into the bolt head and the lower noggin clips onto another bolt head facing towards the grill :)
You'll see once you locate the top one though
Took me two months figure where it clipped on my ABS pump. Glad I'm not alone :)
Thanks for the pic...Oh right its not held on by screws just punch it into the allen key bolt. I will give it a go tomorrow.
