sexybourbon
annoying "tick tock" noise
Morning everyone im getting a little frustrated from a noise in the cabin its coming from just behind the headlight switch / right hand side wiper stalk but behind the dash it appears every five seconds and is best described as a tick tock like a relay or something
Anyone have any ideas as to what it could be ??
Cheers
Hi - not sure what it could be, but I to had a ticking noise everytime i went over a small bump from the boot.
after searching around - i found that behind the rear spoiler mech there was some rust - needed a spot weld to fix and now no more noise :-)
if it coming from behind the headlight switch area and sounds like a relay, it probably is a relay. Take the fuse box shelf out and see if you can hear it better.
Maybe someone has planted a bomb inside the car!!!! :bomb::lol:
As said its most likely a relay.
