p0l1wrath
1993 mfa not saving data?
Im not sure as to wether the data is supposed to be changed but everytime i start my car up my MPG isnt saved? shoudl it be saving? if so what can i do to fix this? or does it not save?
cheers
Sorry if it seems patronising but is the switch on the stalk set to 2?
+1
On setting one it will reset after a few minutes on ignition off
Haha thats cool i only got the car on monday so still getting used to it :bonk: only just found out what that 0120 on the stalk did about 30 mins ago
so im i correct in thinking that setting 1 resets, and setting 2 saves?
cheers
1 = short term memory, which gets erased after leaving the car for an hour
2 = long term memory, doesn't get erased unless you clear it manually or the numbers max out
If you hold the stalk button to the left zero for a few secs, 0
If you hold the stalk button to the right zero for a few secs, -->0 that clears the long term memory
