yacobwood 0 Posted May 12, 2012 Anybody know how to remove this without breaking it? Quote Share this post Link to post Share on other sites
owen g60 10 Posted May 12, 2012 If my memory is correct. Remove the trim on the inside of the tailgate and you should be able to release the clips from there Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 12, 2012 if you mean the glue bit then it can be done..... but take your time & use some heat beforehand. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 12, 2012 Yep hot water poured behind it once the upper clips are off from the kettle softens it nicely ;) be careful though. Quote Share this post Link to post Share on other sites
yacobwood 0 Posted May 12, 2012 Brilliant! I'll give the hot water a go! Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 5, 2017 Resurrection. .... 100% go with hot water. After disconnecting the nuts on the back, I tried heating it up and fishing line wire. Felt like it was going to break. . So boiling hot water poured down the back softened the fixing and made it bendy enough for me to get my hand in and cut the adhesive. Easy and took 10 mins [ATTACH]85165[/ATTACH] Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
