Captaincook 0 Posted April 5, 2004 Can some one confirm where the oil filter is and how do you change it, I have bought the filter, it looks like it just sits inside the housing in front of the engine. Is it hard to change? Thanks im new to corrados and its a VR6 Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 5, 2004 it does in deed sit in the big housing on the front of the engine. have fun trying to remove the cap on the bottom to get it out.... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 5, 2004 Did you get the right filter? Part number should end 561 A Don't over-tighten the cap when you put it back otherwise they tend to break when you try and get them off again! Quote Share this post Link to post Share on other sites
Captaincook 0 Posted April 5, 2004 I hope its the right filter, i'll have a check on the part number, Ive never seen a filter like that, looks like it just sits in the housing. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 5, 2004 it does, it's a cartridge or element type filter. Quote Share this post Link to post Share on other sites
corradoSTORM man 0 Posted April 6, 2004 you need 5mm allenkey & use 36 mm soccet, its not to bad to do. :) Quote Share this post Link to post Share on other sites
