st4stokie 10 Posted May 15, 2012 Can anyone help me out here?? My indicators have stopped working, they were fine untill I've fitted new temp gauge switch & thermostat. Know these are nowhere near or anything to do with the indicators but since I've renewed them my indicators have packed in. Hazard light switch comes on and stays on but nothing happens at the lights. Same with the turn signals. I've checked the fuses and replaced the relay but its still the same. Anyone out there got any idea what could be wrong?? Any advice would be appreciated Thanks Quote Share this post Link to post Share on other sites
STU175 0 Posted May 17, 2012 i would take a guess at the stalk control/hazard button being faulty or wiring plug not in properly? not alot else it can be if youve changed fuse & relay i would have thought Quote Share this post Link to post Share on other sites
st4stokie 10 Posted May 27, 2012 Cheers mate I'll hav a good look at the loom at the back of the fuse box and check the other bits too Quote Share this post Link to post Share on other sites
st4stokie 10 Posted July 11, 2012 BUMP!!! Changed ind switch and stalk and tried another relay also checked loom still no joy. Anyone got any ideas??? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 11, 2012 Whats a temp gauge switch?? Quote Share this post Link to post Share on other sites
st4stokie 10 Posted July 17, 2012 Whats a temp gauge switch?? Goes on the engine block, switches the cooling fans on when water gets to temp Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 17, 2012 Goes on the engine block, switches the cooling fans on when water gets to temp The radiator thermoswitch does this... I would unplug the sensor you changed to see if it goes back to how it was, maybe an earth fault. Relay number 21 is for the flashers - I would try a new one Quote Share this post Link to post Share on other sites
