vw_john
AAAAAAAHHHHHHHHHHHHHH (starting problems after dash removal)
Alright, I'm at my wits end! I removed the dash today to change my heater matrix, then put it all back together.
Now the car wont start AAAH!! what could I have possibly done for this to have happened? all the other electrics work. I can smell fuel after shes turned over for abit.
Please someone give me any idea!
Cheers, John
Has the immobiliser been disturbed possibly? Have you checked that all the relays on the fuse board are pushed fully into place, aswell as checking all fuses?
There is no immobilizer. Well there is the remnants of one, but I left it alone, although I have given it a good poking before but it seems deactivated.
all the relays are fully in and I have only checked the fuel rail fuse didn't think the others would matter much.
I swear this car is cursed!
I shagged my immobiliser when changing my matrix cos i got it wet. It stated but the radio wouldnt switch on, then the windows wouldnt work, then it wouldnt start. I'd completely remove it if I were u for peace of mind anyway. pull a spark plug and earth it on the block. crank the car over to see if it sparks. I did all this, changed fuel pump relay and ignition switch before going for the immobiliser. Hope this helps mate.
Thanks for your help guys, turns out I had knocked off the live wire to the coilpack whilst trying to remove the pipes engine bay side! :brickwall: haha.
Oh well, no harm done!
