Mawrick 0 Posted May 25, 2012 Haven't had any time to look at this my self but what might cause the VR6 to stop when one clutches "out" to do a brake down from a "high" speed (80-90 km/h) and reducing down to 0. Was on a down hill so just "fired" it again on the gear, but haven't seen this behaviour before.....so any tips would be appreciated. Cheers! Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted May 25, 2012 idle control valve? think i read awhile ago that if its sticking or being slow your motor can cut out due to the fact your motor wont be gettting any air when off the throttle. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted May 25, 2012 ahhh. that might be - I presume it's this "sucker": http://www.ecstuning.com/Volkswagen-Corrado--VR6_12v/Engine/Intake/ES4517/ btw, any idea if this is the same on a coilpack and a non coilpack VR6 - as I have a Passat VR6 sitting at the moment not beiing used - I presume these are the same..... thnx for for the tip! :) Quote Share this post Link to post Share on other sites
